Search Forums | Classifieds (5) | Skins | Language
What kind of oil in MFWD hubs?
Five Lock Boll
Posted 3/13/2017 11:14 (#5896405)
Subject: What kind of oil in MFWD hubs?
Northeast Louisiana
Deere 7430 Premium.....if you go to the page it says, it talks about axle housing and gear oil, which conflicts with what the axle housing page says BTW, but never addresses the final drives. Doesn't feel like hydraulic oil, but doesn't smell like gear oil. Anyone know?
wire farms
Posted 3/13/2017 11:18 (#5896413 - in reply to #5896405)
Subject: RE: What kind of oil in MFWD hubs?
Nebraska
Gear oil in the hubs, 85-140, I actually run 80-90 in the 7330 but it gets used a lot in below zero temps and 85-140 is too thick for that I think. Deere also has 80-140 synthetic.
Hydraulic oil in the axle housing
Andy578
Posted 3/13/2017 11:20 (#5896417 - in reply to #5896405)
Ontario
Not sure on that tractor but my 5425 just takes hygard
AGR568
Posted 3/13/2017 11:40 (#5896453 - in reply to #5896405)
East Central Illinois. 39.346676, -87.653484
7320 manual also has conflict.
GL5 (85-140 I think) is used per shop foreman
Hilbilly
Posted 3/13/2017 11:42 (#5896457 - in reply to #5896405)
Rosemont ON
7230 premium and a 7510, 7230 had HyGuard in it when I change so just put that back in it, 7510 had 80-90 so just put that back in it. Asked the JD tech and said they where shipped with either oil from the factory and just put back in what came out so I did, no problem yet.
redwngr
Posted 3/13/2017 11:55 (#5896487 - in reply to #5896405)
Subject: Online manual says:
SW Ont
http://manuals.deere.com/omview/OMAL171429_19/?tM=
Check Oil Level in MFWD Axle Housing
LX1029221
LX1029221-UN-15APR03
 CAUTION: If the oil is hot, it may be under pressure. Unscrew the level plug slowly.
Remove level plug (A). Oil must be level with screw bore. Fill to proper level, if necessary. Tighten level plug to 90 Nm (66 lb.-ft.). Always use a transmission oil listed in the Fuel, Lubricants, Hydraulic Oil and Coolant section.
NOTE: The position of the level plugs varies depending on axle type.
Check Oil Level in MFWD Final Drives
LX1037223
LX1037223-UN-02NOV05
A - Oil Level Mark
B - Level Plug
  1. Turn the wheel until OIL LEVEL mark (A) is horizontal.
  2. Remove level plug (B). Oil must be level with plug bore.
  3. If necessary, top up with oil at this point. Tighten level plug to 90 Nm (66 lb.-ft.). Always use a transmission oil listed in the Fuel, Lubricants, Hydraulic Oil and Coolant section.
NOTE: Change oil in axle housing and final drives after the first 100 hours of operation. Then change after every 1500 hours of operation or once every 2 years, whichever occurs first.
Transmission and Hydraulic Oil
LX1033631
LX1033631-UN-29APR04
Use oil with a viscosity based on the expected air temperature range during the period between oil changes.
The following oils are preferred:
  • John Deere HY-GARD™
  • John Deere HY-GARD LOW VISCOSITY
Other oils may be used if they meet one or more of the following:
  • John Deere Standard JDM J20C
  • John Deere Standard JDM J20D
Use John Deere BIO-HY-GARD II™1 or BIO-HY-GARD™1 when a biodegradable fluid is required.
IMPORTANT: On tractors with IVT:
Only John Deere HY-GARD or John Deere BIO-HY-GARD II may be used.
Do NOT use HY-GARD LOW VISCOSITY. Do NOT use BIO-HY-GARD.
HY-GARD is a trademark of Deere & Company.
BIO-HY-GARD II is a trademark of Deere & Company.
BIO-HY-GARD is a trademark of Deere & Company.
1 BIO-HY-GARD II meets or exceeds the minimum biodegradability of 80 % within 21 days according to CEC L-33-A-93 test method. BIO-HY-GARD meets or exceeds the minimum biodegradability of 80 % within 21 days according to CEC L-33-T-82 test method. These oils should not be mixed with mineral oils because this reduces the biodegradability and makes proper oil recycling impossible.
Edited by redwngr 3/13/2017 11:56
Ag Tech
Posted 3/13/2017 12:35 (#5896575 - in reply to #5896405)
Wisconsin
Hy-Gard in the center section and a Synthetic Gear oil in the hubs is what i like
Maybe not your problem were your at but i have lifted GL-5 gear oil out with my hands at -20 up here so i like 75w90 synthetic in the hubs
Hy-Gard in the hubs was showing wear on the thrust washers if the MFWD was loaded or worked hard
C 6
Posted 3/13/2017 12:57 (#5896611 - in reply to #5896405)
My. 7530 premium uses hygard. Just changed it.
Edited by C 6 3/13/2017 12:59
tedbear
Posted 3/13/2017 13:14 (#5896643 - in reply to #5896405)
I forgot what I used for oil the last time I changed. I had a rather unusual situation. I parked the tractor and got out to look at the drain plug orientation. Luck was with me and I had stopped with the drain plug on the bottom side. Since the oil was warmed up I decided to change it. I put a container on a piece of 2 x 4 so that it tipped toward the tractor and removed the plug. I then looked at the other side to see if I would need to move forward or back once the left side was done. Much to my astonishment, the drain plug on the right side was on the bottom also. It was not perfectly on the bottom but close enough.
I expecting to have to get in/out of tractor several times when doing this alone. It is unlikely this will ever happen again, especially for me.
Edited by tedbear 3/14/2017 07:35
Bruce NW Ia
Posted 3/13/2017 13:55 (#5896708 - in reply to #5896405)
Cherokee County, Northwest Iowa
If I remember the story from service manager, they put HyGuard in the hubs at the factory, primarily because they have that hose right there. He suggested a synthetic oil to be replaced every two years on my 8000 series tillage tractor.
Gerard
Posted 3/13/2017 14:18 (#5896742 - in reply to #5896405)
Woodham, Ontario
Usually gear oil, the 50K tractors with brakes take hyguard.
IowaMark
Posted 3/13/2017 15:28 (#5896857 - in reply to #5896405)
NW Iowa. / SW Arizona
When I bought my first MFWD tractor my trusted JD shop foreman recommended using synthetic oil. Now whenever I buy a MFWD tractor the front hubs get changed to synthetic oil regardless of what was in it previously, might cost a little more but I don't care.
JKM
Posted 3/13/2017 15:49 (#5896890 - in reply to #5896405)
Whitehouse
Seems to be lots of misinformation out there. The old ZF axles on 6/7series used 80/90 in the final drives. Anything with a Deere axle takes regular hyguard in the centre section AND final drives.
http://manuals.deere.com/omview/OMAL201481_19/LX_OILFA1_19_30APR04_...
(image.jpg)
Attachments image.jpg (139KB - 475 downloads)
1586
Posted 3/13/2017 16:23 (#5896954 - in reply to #5896405)
75-90 Synthetic in hubs and axle on all tractors no matter the brand.
trebfms
Posted 3/13/2017 17:41 (#5897076 - in reply to #5896405)
Central Wisconsin
You should follow the manufactures recs. If you put to thick of oil in, the tolerances maybe to tight for the oil to flow threw properly.
Five Lock Boll
Posted 3/13/2017 18:16 (#5897143 - in reply to #5897076)
Northeast Louisiana
And that's exactly what I'm trying to do, hence the question.
Edited by Five Lock Boll 3/13/2017 18:20
Sandcraft
Posted 3/13/2017 19:03 (#5897237 - in reply to #5896405)
South Central ND
We usually put 80 90 gear oil in both. Synthetic if the customer was willing to pay or if the customer used it hard. There were so many suggestions even hygard could be used. I finally came to the decision that any kind of oil is better then no oil. Not the best of thinking as I know the book recommends certain oils but I remember the old 9600 jd used 30 weight in the book which was later changed to hygard so as oils changed so did recommendations. I do know that if that 30 series has a limited slip you need to add the additive in the axle housing.
trebfms
Posted 3/13/2017 21:27 (#5897712 - in reply to #5897143)
Central Wisconsin
I am not sure axle what axle a 7330 has. But I have a 7630 with a 1150 axle and it uses Hy gard ( I use Mobile 424 fluid) in both axle and hubs
Edited by trebfms 3/13/2017 21:29
JD 9400
Posted 3/14/2017 08:20 (#5898335 - in reply to #5897237)
Southern Pa.
Good point on the limited slip additive. Check your tractor build spec sheet to determine what differential you have.
Being as your from Louisiana, 75/90 would be my choice in the hubs at a minimum. I've seen more problems with the hubs than the center differential.
