Search Forums | Classifieds (76) | Skins | Language
welding crack in frame with oil inside
snsw no till
Posted 3/8/2017 05:32 (#5885217)
Subject: welding crack in frame with oil inside
far sNSW , Australia
Tandem disc I just bought has a couple of tiny cracks in the frame. The whole frame can be filled with oil for extra ballast. There is a little oil in there that hasn't leaked out the cracks (looks like sump oil). Wondering if it is dangerous to attempt to weld. If I grind out the crack and carefully Mig weld. The first photo didn't come up very well. 2nd photo, it is in the middle on the right side where the brace meets the main RHS, at the bottom just in the shadow. The crack is about 2 inches, 1/2 underneath and 1/2 on the front.
Edited by snsw no till 3/8/2017 05:38
(disc 001.JPG)
(disc 002.jpg)
Attachments disc 001.JPG (53KB - 88 downloads)
Attachments disc 002.jpg (155KB - 76 downloads)
iseedit
Posted 3/8/2017 05:39 (#5885221 - in reply to #5885217)
Subject: RE: welding crack in frame with oil inside
central - east central Minnesota -
snsw no till - 3/8/2017 05:32 Tandem disc I just bought has a couple of tiny cracks in the frame. The whole frame can be filled with oil for extra ballast. There is a little oil in there that hasn't leaked out the cracks (looks like sump oil). Wondering if it is dangerous to attempt to weld. If I grind out the crack and carefully Mig weld.
Yes, that would be dangerous to weld . . . .  kind of the same as welding a fuel tank or old oil barrel.
If you could drain the oil and fill with water and keep it full, as welding?
Hay Hud Ohio
Posted 3/8/2017 05:47 (#5885231 - in reply to #5885217)
SW Ohio
You have to pull a vacuum on the tube to keep the oil out of the weld.
Rayl
Posted 3/8/2017 06:47 (#5885320 - in reply to #5885217)
Saline County, Mo
Just welded up a crack in a skid steer resivor yesterday. Just knocked off the paint and welded. Still had oil in it. About a 6 inch crack. Did two stringers side by side. I would stick weld if st all possible
rollinsorchards
Posted 3/8/2017 07:27 (#5885409 - in reply to #5885231)
Garland Maine
Hay Hud Ohio - 3/8/2017 06:47
Makes sense to me that if you remove the air then it cant explode.
farmwithjunkrrv
Posted 3/8/2017 08:03 (#5885472 - in reply to #5885320)
South west of Winnipeg MB
I welded a 1000 gallon diesel tank put hot water pressure wash in it as hot as it would got for half hour let the water drain out opposite end then welded a patch on.
rancherman
Posted 3/8/2017 08:09 (#5885480 - in reply to #5885409)
Completely full of oil?  no problem with welding, other than the oil  contamination in the actual crack.   You'll likely see some pretty good  porosity  until  you burn off the oil,  so   make a tiny pass just to  seal the crack,  then   go back over and  lay into it with your filler pass.
I welded up a diesel tank after draining and  throwing  about  10 lbs of  dry ice  in there to displace  any oxygen.  I'm still here.
mb2347
Posted 3/8/2017 11:46 (#5885832 - in reply to #5885217)
drill a hole in the start and at end of the crack, this will stop the crack from spreading . Then weld over holes and the crack.
On the oil, we always take a torch, and burn the oil out of the crack, then weld. Also can take exhaust from a motor, and plumb in disc oil fill hole with a hose, the carbon monoxide from the motor will displace the oxygen in frame and keep thing on safe side
Edited by mb2347 3/8/2017 11:55
jmiller
Posted 3/8/2017 13:26 (#5885984 - in reply to #5885217)
West central Ohio
Might or might not pertain to your situation but, something to think about.
https://www.cdc.gov/niosh/docs/98-146/
Edited by jmiller 3/8/2017 23:14
