NE Ohio | Anyone know where I can find an Oliver front end? It has a Schwartz wide that is wore out on it now, id like to replace it with an actual Oliver. Could be narrow or wide doesn't matter too much to me. Also, what other models share the same front end and will work on the 1650? |
Soil | Google Korves Oliver Waterloo Illinois. Was there last week they had a narrow, might have a wide also. |
Liberty, MO | If you get a wide long wheel base axle be sure to get one with the WISHBONE on the bottom, they turn shorter than the top mtd wishbone. I had a setback axle under a 1969 1650 diesel liked it pretty well, maybe a little rougher ride, BUT not as bad as tricycle front. |
Northwestern IL | 1550-1955 wide fronts will fit on the 1650. We might have a Narrow front laying in the shed. |
Ohio | Maibach they are rite in your neck of the woods . Creston that is NE Ohio to me any way ! |
Sourthern WI | Ask on ytmag.com. There are quite a few guys who parts stuff out that hang out on there. You can also put a wanted ad in the classifieds. |
central ohio..between Springville and Millbrook. | You might also try Smittys Tractor Parts in Massilon. Tim Smith. |
| I think most of the 50 and 55 series will fit, should be plenty at salvage yards. |
southern indiana | Brian lagesse bloomer Wisconsin |
| As was mentioned, Smittys. He has a couple I believe. 330-832-9792 |
NE Ohio | Thanks for all of the replies. I was talking to dad last night and he said he called Smittys about 8 - 10 years ago looking for a front end. Said that he was asking close to 2000 plus the Schwartz. Half the value of the tractor for just the front end seems a little high to me. |
