SE Kansas | I have searched this but did not find what I was looking for. I am running a dry fertilizer spreader with greenstar dry controller pulled by a Caseih with a pro700. I have a 2630 with a cab harness going to the spreader. I am trying to get GPS signal out of the Nav 2. I have a cable from agexpress that plugs into the grey connector on the nav 2 and db9 on the other end pluged into the JD tractor harness. I think we have the pro700 nema settings correct but would like to verify. I can get GPS signal to my planter monitor which is an agleader insight through the grey plug so it is sending a signal. I am probably missing something else any help would be appreciated. |
![](/profile/get-photo.asp?memberid=1807&type=profile&rnd=452) East Central Ia | Try this.
Not the instructions I followed to get GPS from Nav 2 into my 2600 on the planter but it looks similar.
I can't find the link I saved to the instructions I used...
http://talk.newagtalk.com/forums/get-attachment.asp?attachmentid=23... |
![](/profile/get-photo.asp?memberid=33354&type=profile&rnd=435) East Central Illinois / West Central Indiana | Attached is a guide I made up this spring for sending NMEA from Case IH Pros/AccuGuide or Trimble Autopilot to 2630s being used to run Deere planters ... should have the info you need.
Edited by AFS kyle 8/13/2015 08:58
Attachments ----------------
Setup Guide.docx (1778KB - 3405 downloads)
SE Kansas | Thanks that helps a lot. |
