AgTalk Home | ||
You think ag parts are high? Try Hale Pump parts! pic Jump to page : 1 Now viewing page 1 [50 messages per page] | View previous thread :: View next thread |
nemofarmer |
Perry, MO | I am on the Rural Fire Board in our area and got quite a shock when I got the quote for some pump parts. Our department has a 94 model fire truck and a valve came apart and went through the pump, it did not hurt the housing but we need a new impeller, nut, seal, and a brass wear ring. The impeller was a little over $3000 but that was no real shock, the shocker was the brass wear ring that is over $7500. I have learned that this is a Hale Godiva pump, Godiva is a European model that is hard to get parts for. Everything but the wear ring is in the U.S. but it will have to come from overseas with a 12 week lead time. I am going to take it to a local machine shop and see what they think about making one but I am afraid it may be tough without having some specs from the company and not knowing how much it is worn down. We are not a tax based district, just operate off of dues that are voluntary and this is going to eat up most of what we spend in a year. (IMG_0025.jpg) (IMG_0023.jpg) Attachments ---------------- IMG_0025.jpg (56KB - 114 downloads) IMG_0023.jpg (46KB - 130 downloads) | ||
Wheat77 |
Well it is time for a new pump. When some sellers see a public payer like a city, or fire district paying the bill, they go for the gonads. Replace the pump. | |||
nemofarmer |
Perry, MO | The pump is no longer available, and to make things worse, they say it has a different pattern and we would have to replace the transfer case that bolts directly to it as well. | ||
Wheat77 |
Put on your farmer hat, and get things done, or have someone else on the dept. help you. | |||
OlsonKrist |
nw MN | I would say that any machine shop could make that, and you may be surprised how well they can estimate wear in recreating parts. | ||
mike,ohio |
ohio | You might try ARMS INC, anna ohio at 937-3942767.They specialize in repairs of fire trucks. | ||
hinfarm |
Amherst WI | I know. I have a Hale PTO irrigation pump that had a bearing go out of it. If screwed up the brass ring in it. I ordered everything I needed to fix it right, new rings, new seals, bearings ect. $1300 is what the total came to. They weren't even the right parts. I got busy over summer and I am not sure they will even take them back now. | ||
farmnut |
WC Ohio | Scott you've got mail! | ||
LBF Farms |
New York Eastern Finger Lakes | On most centrifugal pumps, the clearance between the ID of the wearing ring and OD of the impeller ring is 15 thousandths. Your ring appears to be what is known as a labyrinth style. | ||
dmh |
Trivoli, Illinois | Call these guys they have a lot of traded in fire equipment http://www.alexisfire.com/ you could use a mild steel wear ring. | ||
nemofarmer |
Perry, MO | Thanks for the replies, I will check with these places and also the machine shop. Hopefully we can come up with a cheaper solution. | ||
Bruised Spud |
Chaffee, Western New York | Our Darrley blew up to the tune of $13000. Insurance covered most of the $14000 for an all new pump. | ||
(Delete cookies) | |
