Northern Kentucky | Just wondering what you guys have done maybe a few pictures to get some ideas. I have 3 different trailers so I dont want to mess with changing the hitch. Tractor is a tandem day cab and has a sliding 5th wheel.TIA |
curtice,ohio | change the hitch on the trailer . most trailer shops sell the adapter |
| I know you said you don't want to mess with changing the hitch, but that's what I do. Takes about 5 minutes, and I don't have a bunch of stuff cobbled on the truck. |
Northern Kentucky | I would have to buy 3 adapters since each trailer has a different style neck. One is square and the other two have different size tubes. That's why im trying to just add a ball. |
Alliance, NE | We added a ball to our freightliner. it sets behind the fifthwheel between the frames. also added a brake controller. sorry no pics. Had a guy in town build it for us |
South Texas | Don't own one, but always thought something like this would be the simplest...
(imagesFSL5KBK3.jpg)
Attachments ----------------
WC MO | your next questions might be what to do about the brakes and wiring unless you've already found the adapter plug. Found some past entries:
http://talk.newagtalk.com/forums/thread-view.asp?tid=367283&posts=7... ball&highlightmode=1#M2902377
http://talk.newagtalk.com/forums/thread-view.asp?tid=402791&posts=1... ball&highlightmode=1#M3452104
http://talk.newagtalk.com/forums/thread-view.asp?tid=348687&posts=8... gooseneck ball&highlightmode=1#M2735894
WC MO | then there is this already made up for several towing applications:
http://popupgooseneckhitch.com/semi-multi-hitch
(Capture.JPG)
SE SD | I don't have to take it off to pull my grain trailer. Steel is one inch thick, eight inches wide. It is still a little high, wish it was a couple inches lower. Depends on the trailer. Threw that last pic in just for fun.:-)
Edited by 260 AR 2/8/2014 16:20
(IMG_0922.jpg)
(IMG_0923.jpg)
(IMG_0921.jpg)
| I like what 260AR has done. We did something similar. Had a ball welded to a large plate removed from an old pickup bed. Cut it to fit, and drilled a few bolt holes and bolted it on. BUT FIRST, we put a heavy channel iron on so that it would run just underneath the ball, to help support the weight on the hitch. Channel is bolted to the sides of the chassis frame, and ball/plate is bolted to the topside of the chassis frame. Everything is mounted a foot or so back of the fifth wheel. Works so far. We don't go "over the road" with it, just use it to pull a tender trailer down country roads. The most load we'd have is 3000 gallons of fertilizer plus the tare weight. showboat |
| brangus02 - 2/8/2014 15:43
Don't own one, but always thought something like this would be the simplest... --------------------------That will work in some cases but if you do not have a 40 foot trailer you jack your front axle up too to work correctly and more weight goes to the rear and you start blowing tires to do it correctly it needs to be down in the frame on a two ton truck check your trailer maf recommended height |
 Central Kentucky | I think you will like the flexibility. Mine is down in the frame so as to stay out of the way of the king pin. The brake controller is an inertia type. No wiring or air lines to tap into. In some states goose neck trailers are treated differently as far as DOT. On a farm plated pulling unit the trailer does require a plate or inspection. If it was on the fifth wheel it becomes a tractor trailer. Nice to have the heavier pulling unit. |
| Mount the ball behind the 5th wheel plate and down out of the way from the king pins on the trailers that you pull. Then you can pull both types. Most will have enough room between the frame rails and run some gussets or flange it and drill some holes.
Edited by Dusty Trails 2/8/2014 18:46
| used 1" plate welded it between the frame rails on my 6x6
(gn hitch.jpg)
gn hitch.jpg (44KB - 513 downloads)
| That I like. How many $$$$$$. |
Southern Alberta | I would not be welding the hitch in as the frame flexing will cause the welds to break eventually. Instead put verticle piece on each end and bolt to verticle part of frame.
What is every one doing for fenders on tractors? Rock throw onto back of tractor is a problem when I pull my gooseneck. |
North Central Kansas | I can't find my photo. But I have one similar to this. But as he states, mine drops down. 1" plate. 4 bolts each side hold it on, and sits over the rear axle. |
