Search Forums | Classifieds (5) | Skins | Language
FROG - Why's it refered to as a FROG ?
iseedit
Posted 12/10/2013 07:09 (#3506432)
Subject: FROG - Why's it refered to as a FROG ?
central - east central Minnesota -
Has this question been brought up before ?
Where did the term "Frog" come from - frog that holds cutting edges . ..  the railroad industry has the term also - frog holds or encase rails (if I recall).
What's the history with that term (frog) ?
TIA
small time
Posted 12/10/2013 07:20 (#3506452 - in reply to #3506432)
Subject: Re: FROG - Why's it refered to as a FROG ?
Home Columbia Mo. Row Crop Farm Novinger Mo.
I have had the same thought.
scott nelsen
Posted 12/10/2013 07:20 (#3506456 - in reply to #3506432)
Leeds, North Dakota
Chris seems to me something with a plow, was a young pup, lets see what Nat brings up, Scott.
ndred
Posted 12/10/2013 07:46 (#3506505 - in reply to #3506456)
s nd
It was easier to spell than giraffe?
bharzman
Posted 12/10/2013 07:57 (#3506528 - in reply to #3506505)
North Central Kansas
ribbit ribbit
scott nelsen
Posted 12/10/2013 08:01 (#3506541 - in reply to #3506528)
Leeds, North Dakota
http://www.lowerymanufacturing.com/images/Moldboard%20Plow.pdf Scott.
mcfarm
Posted 12/10/2013 08:05 (#3506552 - in reply to #3506541)
central Indiana
one definition is a triangular mass used for support. that is how it is used on a moldboard plow. support on the backside for points and moldboard
SOILcattleman
Posted 12/10/2013 08:06 (#3506556 - in reply to #3506432)
Subject: Now don't quote me on it,
West Salem, Illinois
but the term frog when it applies to the railroad is the rail opposite the switch point. It is a large triangular shaped piece that goes off to the two seperate rails. If you kind of stand over it correctley and look down track it does look something similar to a frog, the legs are the two rails and the triangular part is the body. I would take a picture if my tracks weren't under all of this snow!
tkoppel
Posted 12/10/2013 08:17 (#3506589 - in reply to #3506556)
Sanilac Co. Michigan
I don't know.......could be the first thing that "leaped" to mind! Horrible pun, I know.
Ifarm
Posted 12/10/2013 08:29 (#3506616 - in reply to #3506432)
Subject: RE: FROG - Why's it refered to as a FROG ?
The frog is a part of a horse's hoof, located on the underside, which should touch the ground if the horse is standing on soft footing. The frog is triangular in shape, and extends from the heels to mid-way toward the toe, covering around 25% of the bottom of the hoof.[1] The frog acts as a shock absorber for the foot when it makes impact with the ground, decreasing the force placed on the bones and joints of the leg.
The frog is not only a shock absorber, it is also an important part of the horse's circulatory system — it pumps blood up the horse's leg each time the frog makes contact with the ground. The blood flows down the horse's leg into the digital cushion, a fibrous part of the inner hoof located just above the frog which contains a network of blood vessels. The horse's weight then compresses the frog on the ground, squeezing the blood out of the digital cushion, and pushing it back up the horse's legs.
E718
Posted 12/10/2013 08:30 (#3506617 - in reply to #3506556)
Sac & Story county IA
Way over thinking this. Something that looks like a triangle.
hwdcne
Posted 12/10/2013 08:41 (#3506651 - in reply to #3506616)
Soutwest Ks.
But I didn't know that a sweep plow frog had circulation!!!
mcfarm
Posted 12/10/2013 08:41 (#3506652 - in reply to #3506616)
central Indiana
that makes perfect senese Ifarm as that term would of naturally been transferred to a moldboard plow
mhagny
Posted 12/10/2013 09:04 (#3506709 - in reply to #3506432)
Subject: RE: FROG - definitions in dictionary
Dictionary entries provide some clues:
http://www.merriam-webster.com/dictionary/frog
My guess would be things that are triangular in shape, and/or a piece that clasps another (like frog legs & toes wrap around things to hold on).
nosoup4u
Posted 12/10/2013 09:08 (#3506723 - in reply to #3506432)
The triangular part that holds the blade on a wood plane is also a frog.
slowzuki
Posted 12/10/2013 09:51 (#3506813 - in reply to #3506432)
New Brunswick, Canada
I've heard older folks call the triangle web of skin in between index and thumb the frog of their hand, not sure if that is related.
Thud
Posted 12/10/2013 17:11 (#3507728 - in reply to #3506617)
Near-north Ontario, French River
Probably over thinking it again but why call something that's shaped like a triangle a frog?? We all know what plow frog is,but the shape itself doesn't lend itself to the name 'frog', why not call it a triangle???
happytrails
Posted 12/10/2013 18:58 (#3508052 - in reply to #3506652)
Alberta, Canada
Ifarm has it right. There is a reason we measure tractors by horsepower. Harnessing horses was huge in human progress. And the frog in their foot is huge to a horse's soundness. Hence the tendency to label similar shaped objects frogs. That said, in Canada there can be a second meaning.
tater1086
Posted 12/10/2013 21:38 (#3508646 - in reply to #3506432)
Snipesville, GA
There are also frogs on peanut inverters or diggers that hold the digging blade.
Rawleigh
Posted 12/11/2013 15:37 (#3510312 - in reply to #3506432)
White Stone, Virginia
Also the triangular shaped piece that used to hold the bayonet scabbard to a soldier's belt used to be called a frog.
