Search Forums | Classifieds (49) | Skins | Language
Looking for a dump trailer (farm tractor pulled, not truck)
Dan NW IA
Posted 11/30/2013 07:52 (#3480495)
Subject: Looking for a dump trailer (farm tractor pulled, not truck)
Does anyone know who makes a trailer like this in the US?
This brand is made in Canada, i'm looking for something similar but maybe 12,000 - 15,000 lb capacity. New or used is fine.
Thanks
Edited by Dan NW IA 11/30/2013 07:55
(dump trailer.jpg)
Attachments dump trailer.jpg (36KB - 428 downloads)
Al Swearingen
Posted 11/30/2013 08:03 (#3480520 - in reply to #3480495)
Subject: Re: Looking for a dump trailer (farm tractor pulled, not truck)
These guys have big ones. They might make a small one.
http://www.holmeswelding.com
iseedit
Posted 11/30/2013 08:16 (#3480553 - in reply to #3480495)
Subject: RE: Looking for a dump trailer (farm tractor pulled, not truck)
central - east central Minnesota -
Dan NW IA - 11/30/2013 07:52
Thanks
MidSota trailers - Avon Mn, makes them and has been making them for many, many years (previously, under the Sands trailer brand).   http://www.midsotamfg.com/pages/OffHighway-FarmDumpTrailers
Here's the other guy, up the road a bit further, that makes a similar farm rock trailer also . . .  http://stcloud.craigslist.org/grq/4214935986.html
Keep in mind, most of these trailers originated for hand picking rocks - so they are more low profile, for the kids (if you can find them) to get those rocks over the edge.
Edited by iseedit 11/30/2013 08:17
Centerplate
Posted 11/30/2013 08:21 (#3480561 - in reply to #3480495)
We made our own. Took an old dump truck, cut out the eng/trans, cab and made a hitch. Rigged up a PTO shaft and it works great. Don't have a picture right now.
dragon71
Posted 11/30/2013 08:24 (#3480570 - in reply to #3480553)
Farming in NW Iowa
http://www.dktrailers.com/trailers/Mini%20Series%20Dump%20Box&%20Du...
These are mostly meant to pull behind a truck but they would probably have a clevis hitch available.
Edited by dragon71 11/30/2013 08:25
snowden
Posted 11/30/2013 08:41 (#3480618 - in reply to #3480561)
michigan
just like centerplate said we had a dike project a few years back bought a couple old dump trucks that blew up cut off front axle ripped off the cab pulled motor and tranny bent the frame together and made the hitch and the worked slick and a lot cheaper than the ones in the picture
BOGTROTTER
Posted 11/30/2013 09:07 (#3480681 - in reply to #3480495)
Kingston,Mi
Search Http://www.pronovost.qc.ca./remha.html , they build tandem axle trailers for farm use at 15,000 to 16,000 pounds that will tip 3 directions (depending on which hinges/latches are employed). Dealer for NE Iowa and Wisconsin is listed as Dave Balts in Chetek and his phone is 715-837-1427.
Edited by BOGTROTTER 11/30/2013 09:08
OnTheRidge
Posted 11/30/2013 10:42 (#3480871 - in reply to #3480495)
WC Wisconsin
PJ Trailers has worked well for us
stanredrider
Posted 11/30/2013 12:59 (#3481108 - in reply to #3480495)
Westside, IA
Made my own, old cabover IH straight truck frame. 18'X8' box with 4ft tall sides, 1/4" plate for the floor 3/16" for the sides. Use it mainly for hauling old concrete but also works good for stockpiling manure or hauling gravel.
(wgn2.jpg)
(wgn.jpg)
Attachments wgn2.jpg (64KB - 324 downloads)
Attachments wgn.jpg (77KB - 321 downloads)
Dan NW IA
Posted 11/30/2013 16:09 (#3481346 - in reply to #3481108)
Wow, thats sharp.
Thanks everyone for the sources to look!
Delmarva Ag
Posted 11/30/2013 17:25 (#3481452 - in reply to #3480495)
Seaford, Delaware
http://www.bri-mar.com/
Alan
illinois-kris
Posted 11/30/2013 18:51 (#3481636 - in reply to #3480561)
IL
I made my own as well. Removed the cab, engine, trans, & front axle from an old dump truck and folded the frame together. I added an I beam between the motor mounts as a cross member and another I beam perpendicular to the new cross member coming forward to mount my hitch to. I extended the hoses and added the right ends for the cylinder (used 2 because on the truck it used the down stroke side as a reservoir and didn't want to run the tractor dry). I also added a small cylinder to gate latches so I can control the gate from the tractor cab.
iseedit what is the idea for the PTO, some kind of power assist in soupy ground?
(dump.jpg)
Attachments dump.jpg (105KB - 367 downloads)
iseedit
Posted 12/1/2013 06:50 (#3482484 - in reply to #3481636)
I didn't post the pic's and info on the PTO home made jobber . . . . I would guess, PTO to run self contained unit. This would elemanate contimanating the tractors hydraulic system. There are lots of truck hoist, that do not run tractor hydrualic fluids.
illinois-kris
Posted 12/1/2013 12:50 (#3483193 - in reply to #3482484)
IL
I understand that then. I worked my bed up and down with the bobcat with the hoses off to get as much of the old fluid out of the cylinder as possible then stuck a long air gun in to blow the rest out. I've seen 5-6 old grain trucks turned into trailers like this and never could understand the transmission hooked to the PTO. I suspected that the truck didn't put out near the pressure as a tractor hydraulics so they were afraid of blowing the packing out of the cylinder.
Chris 924
Posted 12/1/2013 16:06 (#3483534 - in reply to #3480495)
Nova Scotia
most are hooked to pto pump due to your tractor does not have enough oil to push up a larger 4 stage hoist.
