Best tire sealant
nw_bearcat
Posted 8/6/2013 21:08 (#3252133)
Subject: Best tire sealant
Top middle of MO. land of green hills and grass
Looking for something to put in a set of skid loader tires.
Not to interested in foaming them at this point.
Looking at the 2 grades of Ultra seal from gemplers, or Slime. Any others to consider?
smilin jack
Posted 8/6/2013 21:12 (#3252152 - in reply to #3252133)
Subject: Re: Best tire sealant
SW North Dakota
Don't think slime will work because of the pressure you air them up to... this has worked for us http://www.skidsteersolutions.com/Skid-Steer-Tiretyte-Tire-Sealant-...
fox128
Posted 8/6/2013 21:12 (#3252153 - in reply to #3252133)
West Central IA
Liquitube, formerly known as Amerseal. Good stuff.
Edited by fox128 8/6/2013 21:13
twraska
Posted 8/6/2013 22:41 (#3252468 - in reply to #3252133)
Subject: RE: Best tire sealant
Wallis, TX
We buy the stuff Gensco (the airplane tire people) sells and it works great.  Ran it in all the tires in Africa with great success.  Son cut a sidewall on his new mower couple of weeks ago.  About a 1/4" slit on the sidewall, plugged it to slow the leak and poured some in, its been up since then.
Hayinhere
Posted 8/6/2013 23:26 (#3252566 - in reply to #3252133)
Central NE
I bought a few 5 gallon buckets of Ultraseal this spring and am very happy with the results.   I no-till into cornstalks and had all 4 tractor tires and 3 of my planter tires that had slow leaks. One of my front tractor tires had been "repaired" at the tire shop THREE times and still leaked.  I have a second planter that also had seeping tires and used it them as well.  Also had a 4 wheeler cart that always had flat tires every time I went to use it.
I put it in all of these without fixing any of the leaks first and it sealed them ALL up.   One tire I had to add air the second day before it sealed - it just needed to be moved around more.   And I had no more new flats or low tires this year.  It really saved me a lot of grief and was my best purchase this year.
Try calling ultraseal directly for a good deal.
nw_bearcat
Posted 8/7/2013 05:30 (#3252688 - in reply to #3252133)
What did you use for a pump with the ultraseal? They want as much for the pump as they do for a bucket of goo. Looks like the pump will put the stuff in without letting out the air...not a big deal to me
Applicator
Posted 8/7/2013 05:32 (#3252693 - in reply to #3252566)
Ultra Seal makes different grades of sealant. http://www.ultraseal.com/pages/extreme.html I do not believe that Gemplers carries the extreme duty grade. With their pump, you do not have to deflate the leaking tire. It is not cheap, but it works.
bcboy
Posted 8/7/2013 10:14 (#3253209 - in reply to #3252688)
Amerseal 5 gallon bucket with pump, simple works excellent!
