Search Forums | Classifieds (53) | Skins | Language
Bent corn head 612c
shulerfarm
Posted 10/25/2026 07:23 (#11785712 - in reply to #11785693)
Subject: RE: Bent corn head 612c
Holly Hill, SC
Not sure what to tell you. Pull with Lull or fork lift at the angles needed to bent it back. Do you leave it hooked to the combine while pulling? Pull too hard and end up breaking something else. If a tube is obviously "compressed" on one side, cut half the tube with a cut off wheel, pull with equipment and weld back shut. On the tension stressed side of the tube you might can heat it red hot and throw water on it to shrink it.
