Posted 10/24/2026 22:11 (#11785573 - in reply to #11785528) Subject: RE: 2366 wont take beans! Rotor plugged again..
Michigan
Good luck! One thing I forgot to mention—when you plug do you stall or almost stall the engine? If engine rpms are not dropping (to the point of stall) when you plug then that points in the direction of the rotor drive (belt, torque sensing sheave, etc).
