Search Forums | Classifieds (126) | Skins | Language
Agco sv1 speed problem continued
JamesL2
Posted 5/12/2026 21:19 (#11644612 - in reply to #11644506)
Subject: RE: Agco sv1 speed problem continued
Oregon
Massey1155 - 5/12/2026 19:34
So it works in turtle but not rabbit?
The wheel slip is for 3 point stuff and won't make a difference.
Throw the engine load to 30 % and see what it does.
Go into your data screen and see what the clutch position is.
Turn key on, press and release clutch, hold up arrow till left screen changes.
Select data and scroll left or right till you find it.
It reads from 0 to 100%
Make sure your brake switches are working.
Otherwise its what we told you to check last time
It has worked in turtle. I can't say if it has worked in rabbit.
I will check that out.
Throw the engine load to 30% ? I assume that's the engine underspeed supervisor knob? I can look at the manual in the morning if you don't reply.
Ok thanks ill go thru this again tomorrow.
Edited by JamesL2 5/12/2026 21:20
