![](/profile/get-photo.asp?memberid=800&type=profile&rnd=453) Alton, Ia | DBindiana - 6/8/2024 09:40
Jon - 6/8/2024 08:39
Have everything in 250g totes, turn on switch watch cone fill. Hardest part is dumping 8 or 10 bags of ams in top of tank. Lift pallet above tank with forklift and dump away. . Why are you not using the cone? We dump all our spray grade AMS through our cones, and they are even on the suck side. As long as you have water being injected into the cone, you're fine.
Same, sort of. I open both tank and cone valves, pump off, fill cone about 2/3 full, close valves, dump AMS in, while pumping some straight water across. A 30 gal cone will hold probably 4 bags easy, maybe 5 don't know for sure. Suck from both, do not suck from just the cone or you will be unplugging your pump. But it feeds in fine and the weeds die. We had a pallet of "chunky" AMS, we'd prefill the cone before and let stuff dissolve, worked fine. | |
