Search Forums | Classifieds (20) | Skins | Language
Deutz Air Cooled Irrigation Engines ?
AllRed
Posted 7/2/2012 14:38 (#2462420)
Subject: Deutz Air Cooled Irrigation Engines ?
NWTN
Anybody got one ?
Thinking about using one , mechanic said very reliable
Dont know much about them would appreicate any info good or bad
Thanks in advance
plowboy
Posted 7/2/2012 14:47 (#2462439 - in reply to #2462420)
Subject: Re: Deutz Air Cooled Irrigation Engines ?
Brazilton KS
No irrigation engines here, but Duetz engines are reliable and pretty economical to own, feed, and repair. We have them in other machines.
dougpettman
Posted 7/2/2012 14:50 (#2462441 - in reply to #2462439)
Tillsonburg Ont
They are stingy on fuel.Just keep the fins on the sides of the cylinders clean.I had Allis tractors and you pulled the cover to keep clean/check and they ran fine.Not much heat in the cab in winter though.
Posted 7/2/2012 15:43 (#2462507 - in reply to #2462441)
With an irrigation engine, the jug fins and oil cooler fins are a prime concern. When they put them in combines, the additional dust and chaff they were exposed to would eat away at the fans and sharpen the fan blades to the point that they would no longer move enough air to keep the engine properly cooled. When I talked to an experienced parts supplier about a new fan, he seemed puzzled because he had never sold one. AC dealers sold a lot of them though and there were about three different grades a guy could buy, depending on how much money you wanted to spend and how long you intended to run the machine. As I remember, the hardened version was around $800 at the time, for just the fan.
The thing that makes a Deutz so fuel efficient is they can run a lot hotter than a liquid cooled engine. Liquid cooled engines are limited in the temp they can run by the boiling point of the liquid coolant. That temp puts an upper limit on how hot the engine can run. There is nothing to say that an engine can't run even hotter without damage. Because the Deutz is directly air-cooled, the running temp can be determined by things other then the boiling point of the coolant and it will be hotter. The hotter an engine runs, the less heat is wasted by heating parts that have been cooled too much because we don't want boiling coolant. We also do away with problems caused by cavitation erosion on the cylinder liners of a liquid cooled engine.
Bern
Posted 7/2/2012 18:32 (#2462750 - in reply to #2462507)
Mount Vernon, WA
With pressurized cooling systems, a person should be able to take the water temp up to 250 degrees plus if needed. The reason they don't is because pistons start to melt and valves start to warp if it gets much hotter.
If an air cooled diesel engine was that much better on fuel, then why don't you see any of these engines in class 8 trucks, where PACCAR, Freightliner, and others are looking to save every last drop? They are absolutely anal about fuel economy right now. Cummins has even changed their oil pump to reduce parasitic losses, but no-one is talking about air cooled engines.
Edited by Bern 7/2/2012 18:36
plowboy
Posted 7/2/2012 18:46 (#2462770 - in reply to #2462750)
Brazilton KS
Hasn't it become problematic to get an air cooled engine to meet the ridiculous emissions requirements?
GreySage
Posted 7/2/2012 18:57 (#2462784 - in reply to #2462770)
Subject: Yep.
Plus noise in Europe. Air cooled can not pass either one. The Deutz fuel system smokes when head is cool. Nothing can change that.
Bern
Posted 7/2/2012 18:57 (#2462785 - in reply to #2462770)
Mount Vernon, WA
It's problematic even with a water cooled engine. My earlier point though applies to both current as well as prior non-emission engines. That is, if air cooled engines are so great from a fuel economy standpoint, why aren't they used in class 8 trucks?
Edit: I mis-understood your earlier statement. You are probably correct. An air cooled engine likely is much tougher to regulate emissions on, especially in cold climates/low loads. That may be another reason why they are not used in trucks.
Edited by Bern 7/2/2012 19:04
GreySage
Posted 7/2/2012 19:03 (#2462798 - in reply to #2462785)
Someone has to buy them. Class 8 was owned by Cummins and Cat. Notice how Mer and Detroit were treated and are still treated. Toss in air cooled to see really slow selling trucks regardless of power and utility. Buying is still an emotional experience.
Bern
Posted 7/2/2012 19:10 (#2462813 - in reply to #2462798)
Mount Vernon, WA
Series 60 Detroit was the best selling engine in trucks throughout the late 80s and early 90s, and Detroit has stayed competitive and in the game ever since.
Edited by Bern 7/2/2012 19:15
(Market share.jpg)
Attachments Market share.jpg (45KB - 693 downloads)
GreySage
Posted 7/2/2012 19:30 (#2462846 - in reply to #2462813)
Subject: How much govt mandate in that chart?
We had a 60. I liked it. Couldn't get someone to sit behind the wheel. Given a choice, the choice is Cummins or Cat. Was Cat. Check the discounts on used trucks with 60s in them.
plowboy
Posted 7/2/2012 19:48 (#2462887 - in reply to #2462846)
Subject: RE: How much govt mandate in that chart?
Brazilton KS
Show me the discounts....I'll take 'em.
I'm not fond of working on Cats.
plowboy
Posted 7/2/2012 19:47 (#2462883 - in reply to #2462813)
Brazilton KS
Is it a coincedence how the slope of the DD and the MBE seem to always be inverse?
mschultz
Posted 7/3/2012 01:25 (#2463493 - in reply to #2462883)
Oregon
Good eye. -Mike
plowboy
Posted 7/2/2012 19:14 (#2462819 - in reply to #2462785)
Brazilton KS
I never really understood the emissions situation.  I was told that Duetz was pushed away from the air cooled engine by emission requirments, but previously I was also told that Duetz virtually owned the underground mining market because they were the only diesels which could meet the stringent emissions requirements.
I never thought those two statements regarding the same engine made sense.
I do know our Duetz tractor runs pretty clean compared to similar age Deeres, but it is no where near as clean as the new Perkins of similar size.   Even the newer small NH and Deere turbo engines don't seem nearly as clean as the late '90s Perkins 100- series engines.   This is my unscientific observation...basically based on how long you can have one running in the closed shop comfortably.  I think the Fastrac or telehanders could run for an hour and still be fine, compared to the 4010 or 4000 Deere that have you heading for the door a minute.   The TS110s or 6415 Deere will have your eyes burning in ten minutes or so.  I think the old D8006 is about comparable to them.
olwhda
Posted 7/2/2012 21:32 (#2463084 - in reply to #2462770)
Liberty, MO
I have 2 Deutz AIR and OIL cooled engines,( Farm Tractors) and I was told that they ran too cool and couldn't pass the EPA CRAP, and if kept clean around the cylinders and heads, you can't get them too hot, even in 100 degree temps, I know this for a fact. like another poster said, cab heater isn't very good if setting still but moving around it works fine, ask my wife, Auger Wagon Operator.
deeredriver
Posted 7/2/2012 21:34 (#2463092 - in reply to #2463084)
Alma NE
What tractors do you have i have a 7145 and the cab heater is ran from the engine oil it gets nice and warm in my cab fast in the winter .
olwhda
Posted 7/2/2012 21:38 (#2463103 - in reply to #2463092)
Liberty, MO
9150 and 9190 and traded a R-52 Deutz powered, Engine oil in cab heatercore.
Posted 7/2/2012 19:50 (#2462891 - in reply to #2462750)
According to Deutz, the max permissable oil temp for an Air-Diesel  is 257°F. Max permissable temps for the cylinder fins is 338°F. To keep water from boiling at that temp you will need a minimum of 115 PSI. Good luck with designing a radiator and plumbing system to handle that and you'll need an extra measure of luck to deal with a superheated steam explosion that will occur when a hose or radiator bursts. Of course, you will need even higher pressures to keep the hot spots along the cylinder liners from boiling and really causing a cavitation wreck.
While high operating temps are great for efficiency, you can imagine the amount of NOx the high temps in a Deutz would cause. With the advent of exhaust after-treatment solutions like SCR, we may indeed start to see some air-diesels begin to appear in trucks again, like was common in Europe in the past.
Bern
Posted 7/2/2012 22:34 (#2463238 - in reply to #2462891)
Mount Vernon, WA
I just went to the Cummins QuickServe website and found a spec for maximum permissible oil temp for an ISX (truck) engine. It is 252 degrees. Pretty much the same as the 257 you quoted for the Deutz.
Just because the EXTERNAL cylinder fins on a Deutz run at 300 degrees plus, this does not mean that the INTERNAL cylinder wall temps differ that much between a water-cooled and an air cooled engine. Just look at how much more cooling surface area there is on a Deutz.
The oil temps in a water cooled engine are typically 20-30 degrees higher than water jacket temps, so if the cooling system is running at 210, then the oil is going to be in the 230-240 degree range, and so the overall INTERNAL engine temps (exhaust, oil, piston crown, valve, etc.) are pretty much the same between an air cooled and water cooled engine.
An aluminum piston is basically the same, whether it's used in a Cummins (or Deere or Cat or whatever) or a Deutz engine. The cylinder wall temps cannot exceed "x" (whatever we want "x" to be) without causing overheating and subsequent scoring of the piston and cylinder wall. We KNOW that running a water-cooled engine much above 230 or so will cause problems with piston scoring. In my professional opinion, this gives the air cooled engine NO advantage in the fuel efficiency department.
What I'm trying to say is that the INTERNAL temps of a Deutz engine cannot be significantly (if any) higher than that of a water-cooled engine, hence no real fuel economy advantage.
NOx levels are more a function of exhaust temps than cooling system temps. If indeed, as you say, a Deutz engine is more fuel efficient for the reasons you stated above, then NOx levels should be LOWER in a Deutz, because that means that more of the heat energy of the fuel is being converted to useable HP, which should translate to LOWER exhaust temps and lower amount of NOx.
Posted 7/2/2012 23:08 (#2463303 - in reply to #2463238)
A diesel without EGR always runs lean or with a surplus of oxygen. If you build a very hot fire during the combustion process, all the carbon in fuel gets converted to CO2. We are still left with unused oxygen and some of that combines with the nearly inert N that is in the air the engine inhales and we have NOx as part of the exhaust gasses. If the fire isn't hot enough to literally burn some of the N, NOx isn't as big a problem.
As for the water jacket temps compared to the finned jugs, you have just stumbled on why higher cooling jacket temps makes an engine more efficient. If you cool the cylinder sleeve to 200° and only cool the finned jug to 300°, then when you light the fire in the cylinder, more of the heat and expanding gasses are used to reheat the cylinder to the point where it begins to make energy than will be used in a cylinder that is already 100°+ hotter than the liquid cooled version. Air-Diesel wins here.
Bern
Posted 7/3/2012 00:53 (#2463476 - in reply to #2463303)
Mount Vernon, WA
'fraid not. You missed my earlier point, and that is, the INTERNAL parts (e.g. pistons, valves, etc.) run at very similar temps in both air cooled and liquid cooled engines. Just because a wet liner is surrounded by 200 degree coolant, that does NOT mean that the cylinder wall is also 200 degrees. If combustion temps peak at over 1000 degrees, then cylinder wall temps are considerably higher than 200 degrees. Similar in a Deutz, the wall temps are higher than 300. As the heat radiates away from the walls and into the fins, the temps cool to 300.
Also, OIL is the primary cooling medium for internal engine parts (e.g. piston cooling jets). If both Cummins AND Deutz specify a 250ish maximum temperature, that tells me that the internal parts operate at very similar temps.
I remain convinced that liquid-cooled and air-cooled diesel engines enjoy similar combustion efficiencies (i.e. fuel economy). The only real advantage to a Deutz in my opinion are the elimination of cavitation erosion (virtually a non-issue in today's liquid engines), and the increased reliability due to fewer cooling system parts. Of course, liquid cooled engines have other advantages which I will not list here.
Again, if the fuel economy advantage was that great, you'd see an air-cooled something in a class 8 diesel truck. Truck makers will spend millions to get even a few percent increase in mileage. Haven't heard any rumors about air cooled engines being considered for a Kenworth.
mschultz
Posted 7/3/2012 01:28 (#2463494 - in reply to #2463476)
Oregon
'fraid Ed still wins. Real world experience, nothing is more efficient with fuel than the air cooled Deutz. Many of the posters here will tell you the same. -Mike
Bern
Posted 7/3/2012 09:38 (#2463816 - in reply to #2463494)
Mount Vernon, WA
Talk is cheap, and is just that, talk. One guy in this thread raved about how much better his Deutz was than his old 2-stroke Detroit, to which I replied "It's not hard to beat a 2-stroke Detroit in the fuel consumption area". Still another poster in this thread said his Isuzu was among the best. Last I checked, Isuzu engines were water cooled.
Unless and until I see a Nebraska-style test that shows otherwise, I remain convinced that a water-cooled diesel engine will do better on fuel than a Deutz in an irrigation pumping application when the water-cooled engine is using the pumped water as the cooling medium. In this scenario, the water-cooled engine enjoys at least a 5% advantage in parasitic losses due to not having to drive a fan.
Edited by Bern 7/3/2012 11:03
Posted 7/3/2012 08:57 (#2463732 - in reply to #2463476)
Subject: So which will be more efficient?
A diesel engine with a non-pressurized cooling system and a 150° thermostat?
The same engine with a non pressurized cooling system and a 180° thermostat?
The same engine with a pressurized cooling system and a 190° thermostat?
The same engine with your pressurized system and a 250° thermostat?
My money goes on the engine that can run the hottest without burning down . . .
Bern
Posted 7/3/2012 11:02 (#2463949 - in reply to #2463732)
Subject: RE: So which will be more efficient?
Mount Vernon, WA
You don't understand sir, so let me illustrate this way. Say you have a solid steel pipe sticking out of the ground, surrounded by a puddle of water. This pipe is 3 feet long, 2 feet of which are exposed to the air (1 foot in the ground). You wish to shorten said pipe by one foot, to leave only one foot exposed. You get out your torch and cut the pipe. After cutting said pipe, what is the temperature of this remaining length of pipe immediately next to the cut area? I bet you wouldn't touch it!
In your arguments about the Deutz engine, you are claiming that the pipe in my example above is the same temperature for its entire length as the water (or air) that it is submerged in or surrounded by. It would be if you let it set for an hour, but not immediately after you cut it with a torch.
Now then, the pipe is the cylinder wall, and the ground end of the pipe is the side of the cylinder wall surrounded by coolant (or air in the case of a Deutz). The torch is the heat of combustion. Is the cylinder wall temp 300 degrees during combustion? Of course not, it's much higher. If you wish to argue that the cylinder wall is not 1 foot thick, that's fine, cut the pipe as close as you can to ground level. When you're done cutting, the water will be sizzling like a bowl of rice crispies right after the milk is poured.
My point is that the cylinder wall (and piston) temps are very similar between the air cooled and liquid cooled engines. If my explanation above doesn't convince you of that, then I give up.
Edited by Bern 7/3/2012 11:42
Bern
Posted 7/2/2012 15:29 (#2462491 - in reply to #2462420)
Subject: RE: Deutz Air Cooled Irrigation Engines ?
Mount Vernon, WA
Everyone seems to rave about the Deutz engine fuel economy, but for an irrigation pumping application, a water cooled engine should theoretically do better on fuel if you use the pumped water for cooling, as there will be no cooling fan power loss. Yes, a water cooled engine uses a water pump, but the parasitic load of a water pump pales to that of a fan. If fuel economy is your prime concern, I would look at that pretty hard myself.
I would find a turboed, water cooled engine that would be running at about 50-75% load all day long. I would cool and aftercool it with the pumped water. That should give you ideal fuel efficiency.
davpal
Posted 7/2/2012 18:11 (#2462716 - in reply to #2462491)
Mid Michigan
I totally disagree about the fan taking more power than a water pump. Air cooled is much better in just about every application. Water pumps take a lot of power to turn. Ask any drag racer. Buy the Deutz and run it 30,000 hours.
Bern
Posted 7/2/2012 18:28 (#2462744 - in reply to #2462716)
Mount Vernon, WA
I stand by my statement. Fans consume at least 5% of the engine horsepower, and that's a conservative estimate.
As for drag racers, they are looking for every last ounce of HP they can get. If they can spin the pump with an electric motor when not running down the strip, and turn it off when running the 1/4 mile, then that might make the difference between losing and wining. Look at the dinky little electric motor they use to turn that pump with, and then try and tell me that a water pump takes more HP than a fan.
Edited by Bern 7/2/2012 18:38
plowboy
Posted 7/2/2012 18:47 (#2462771 - in reply to #2462744)
Brazilton KS
Don't really even need a water pump if you are going to raw water cool it off a pump set.
Bern
Posted 7/2/2012 18:56 (#2462781 - in reply to #2462771)
Mount Vernon, WA
Cooling it directly with raw water would be the worst thing you could do, and is not what I am talking about. For one, the engine would run way too cool, and there goes your fuel efficiency, not to mention all of the other bad side effects. What I'm talking about is running conventional antifreeze in the block, along with a hot thermostat, and with a water-to-water heat exchanger like marine engines use. I would set up my engine to run 215-220 degrees water jacket temp all day long.
I would also use a water-to-air aftercooler, the water in this equation being the pumped well water. This would get my turboed air temp down into the double digits, which would be great for oxygen intake (combustion efficiency) and things like piston top and valve cooling.
plowboy
Posted 7/2/2012 19:38 (#2462863 - in reply to #2462781)
Brazilton KS
What is the advantage of a heat exchanger and a hot thermostat compared to just running a hot thermostat with raw water?  Other then water quality problems, I don't see any advantage to the added complexity.  Can't the operating temperature be maintained by controlling how much flows through the thermostats?
cocodrie
Posted 7/2/2012 19:51 (#2462893 - in reply to #2462863)
Mississippi Delta
One reason for a heat exchanger is if your pump stops pumping water, there is no water going into the engine. Also, some of our water is so high in iron if you ran it straight into the engine, by the end of the season you'd have a mess. With a heat exchanger, you can have antifreeze circulating through the block instead of raw water.
plowboy
Posted 7/2/2012 19:53 (#2462898 - in reply to #2462893)
Brazilton KS
If your pump stops pumping water, do you really want it running?    Don't you have a murphy switch on that?
Yeah, I get the water quality problems.
cocodrie
Posted 7/2/2012 19:57 (#2462903 - in reply to #2462898)
Mississippi Delta
No Murphy on the pump. Probably should have one though.
Adrian
Posted 7/2/2012 22:37 (#2463241 - in reply to #2462898)
South Georgia
Most setups would have an indirect Murphey on the pump, via the pivot's pressure switch and pump control mechanism. However, it's common that the engine is also driving a generator to power the pivot. In this case, it's sometimes necessary to walk the pivot without pumping water, in order to spray, plant, or whatever. So, it's still desirable to have a conventional radiator rather than a heat exchanger in some situations.
Adrian
Bern
Posted 7/2/2012 22:05 (#2463170 - in reply to #2462863)
Mount Vernon, WA
A properly functioning cooling system really needs to be a closed-loop system, which you obviously cannot do when you are pumping well water into the engine block. During warm up, and during part loads, a portion of the coolant is recirculated through the block and heads. This would not work well if raw water was the sole inlet.
Also, to get temps above the boiling point, the system would need to be pressurized. That alone sinks the raw water idea, not withstanding the water quality issue. Then of course is the no nitrates for liner protection problem.
plowboy
Posted 7/3/2012 03:39 (#2463517 - in reply to #2463170)
Brazilton KS
I'll concede that boiling point at maximum pressure attainable is a limitation for a conventional engine design, however I am not sure I belief that system pressure must necessarily be any lower using raw water then using a closed system. Isn't it going to be possible to pressiurize the block to any pressure short of the mainline pressure? Also, if alllowed to design to purpose, I would think that operating above boiling would be possible given that there is an endless supply of water. It would just be necessary to provide for adequate cooling to the cylinder in presence of steam pockets.
Bern
Posted 7/3/2012 11:09 (#2463966 - in reply to #2463517)
Mount Vernon, WA
Not sure how well that would work - way too many variables to think about here. My biggest concern would be maintaining proper flow during closed and part open thermostat operation, when the system is in normal bypass mode. Incoming pressure from the irrigation pump would likely overwhelm the closed or partially closed thermostat. Keep in mind that in a normal cooling system, the inlet (bottom of the radiator) is normally under suction.
I can't argue AGAINST what you're saying here, but I cannot advocate for it, either.
sam801
Posted 7/2/2012 16:48 (#2462601 - in reply to #2462420)
We have 2 of them, 4000hours each, have never caused any problems at all, the only downside is they are very loud engines, which doesnt worry us because they are in an isolated area.
farmer79
Posted 7/2/2012 17:42 (#2462672 - in reply to #2462420)
SE IL Mt.Erie, IL
We have four running on pivots as I type. They are all in the 1000-2000 hour range so I can't tell you about long term but I think they have more than paid for themselves in fuel savings versus the old Detroit and deere engines they replaced. We love not dealing with a radiator and water pump. Just keep a new fan belt on hand. We have had a couple turbos go bad and leak oil and one has issues with the governors in the bash injection pump but as far as the air cooled and other main engine parts no issues. The generator company we bought from sold the first one with too small of an engine. I would guess it was running 110-120% power for the first couple years. Turbo went out from being cherry red the whole time but we have put a 8.3 cummins on it now and that deutz has a lighter load on another pivot
Edited by farmer79 7/2/2012 17:46
wayneNWAR
Posted 7/2/2012 18:15 (#2462725 - in reply to #2462420)
north west arkansas
I have 3 and they have been great, and mine burn 1 gal an hr. Mine are 4 cyl. And has a turbo and it is pushing 19,000 hrs.
hwdcne
Posted 7/2/2012 18:24 (#2462733 - in reply to #2462725)
Soutwest Ks.
I used to have a V8 Deutz in a Gleaner combine and the cost of any repair (German parts) negated any advantage there might have been with fuel economy and I didn't think the fuel economy was anything special but I realize this was a different application. It does appear they are durable, well built engines.
plowboy
Posted 7/2/2012 18:53 (#2462778 - in reply to #2462733)
Brazilton KS
I priced stuff for a friend the other day, I seriously doubt you can rebuild any other 100-200 hp engine for the same cost as you can a Duetz 912 or 913, unless it was a 2 stroke DD.  About $200 per hole gets you complete pistons, jugs, and  heads.    I don't  think the bottom end of a Duetz wears out.  Lol...the block and crank on a 913 are about the size of most 10L
datyerdog?
Posted 7/2/2012 18:40 (#2462762 - in reply to #2462420)
i have a 912 on an irrigation pump. 30-40% better fuel efficiency over previous engine (N series 3-71 Detroit). 4700 hours and going strong...
plowboy
Posted 7/2/2012 18:57 (#2462786 - in reply to #2462762)
Brazilton KS
No offense intended, but you do realize that you are comparing to about the least efficient diesel engine you could find.
I kinda like DD engines....but without a turbo the one thing they weren't was fuel efficient.
Bern
Posted 7/2/2012 18:59 (#2462792 - in reply to #2462762)
Mount Vernon, WA
It's not hard to beat the fuel efficiency of a 2-stroke Detroit.
plowboy
Posted 7/2/2012 19:41 (#2462872 - in reply to #2462792)
Brazilton KS
you should add naturally aspirated to that.
92TA engines hold their own against their contemporaries pretty darn well, especially with DDEC.  Go look up fuel curves for an 8V92TA and a Bog Cam or Big Cam III if you don't believe me.
Bern
Posted 7/2/2012 22:00 (#2463156 - in reply to #2462872)
Mount Vernon, WA
I have no doubt that a turboed 2-stroke does better than an NA (or, more accurately, a supercharged-only) 2-stroke, but everything else being equal, a 4-stroke will always outperform a 2-stroke when it comes to fuel efficiency, for the simple fact that a 4-stroke allows more time (in crank angle degrees) on the power stroke to take advantage of more of the heat stroke. By the time a 2-stroke piston is halfway down the bore on the power stroke, the intake ports are exposed.
Emissions are another big problem with a 2-stroke, and that is one reason the series 60 came out when it did (1987), because the government was not fond of the 2-stroke's emissions, even back then.
The only thing a 2-stroke has over a 4-stroke is HP/weight ratio.
plowboy
Posted 7/3/2012 04:01 (#2463522 - in reply to #2463156)
Brazilton KS
Has something recently been introduced? The last I knew the most fuel efficient diesel engines the world was a 2 stroke.
Bern
Posted 7/3/2012 09:30 (#2463796 - in reply to #2463522)
Mount Vernon, WA
And which engine would that be? You said yesterday below that a DD 2-stroke was not exactly a fuel economy champion. I am not aware of any other 2-stroke diesels.
plowboy
Posted 7/3/2012 13:42 (#2464200 - in reply to #2463796)
Brazilton KS
I may be outdated, but I thought the most efficient was a big  2 stroke Sulzer from Switzerland.  I remember it being in all the diesel publications when it came out.
John..neAR
Posted 7/2/2012 20:19 (#2462933 - in reply to #2462420)
Caraway, AR
Have 2 914's new last year.
No problems yet. One thing's for sure......outside temp doesn't bother them......been 103 here all last week. I've got it loaded too.
A question for the experts: Is the temp gauge for oil or air?............(factory gauge panel)
Thanks, John
wayneNWAR
Posted 7/2/2012 21:54 (#2463137 - in reply to #2462933)
north west arkansas
Im no expert, but on mine the 2 older 913 motors it is air and on my 914 it is oil. The dealers always told me that the oil was much better and they usually convert them over.
John..neAR
Posted 7/2/2012 22:06 (#2463173 - in reply to #2463137)
Caraway, AR
Mine must be oil then, only goes to 300*.
Thanks, John
David in MD
Posted 7/2/2012 21:18 (#2463049 - in reply to #2462420)
I've got a TCD 6L914 going on 3 years old with 1600 hours that has been a disappointment because it's burned 2 quarts of oil per day since new. Deutz bases their permissible oil consumption as a percentage of the fuel used so mine would have to burn 4 qts per day for them to do anything about it. I did have the nearly $400 fuel lift pump replaced under warranty since the mechanic found it wasn't developing the pressure it was supposed to. At those prices I'm not looking forward to buying any real parts. Mine burns 4.8 gallons per hour turning a 75 hp line shaft turbine pumping 800 gpm at 32 psi and turning a 15 kw generator on the front so I haven't been overly impressed with fuel consumption. When I purchased it my choices were a 6 cylinder 6.8l Deere Tier II mechanical engine which really wasn't legal in a stationary application or a 4 cylinder 4.5l Deere Tier III electronic engine or the Deutz. Irrigation guy said he didn't like electronic engines placed between a 1200' lightening rod and a 600' ground rod. My Deutz is mechanical and was Tier III although I can't see how it could be with the amount of oil it burns and the smoke. I'm running mine at 1750 rpm for the correct water volume and voltage with temps running from 180 to 210 degrees. It doesn't seem to have an abundance of power as it is slow to come up to speed under load. Perhaps it will last 20-30k hours and I'll have to settle for putting 2 qts of oil in it everyday but my next engine won't be a Deutz. There is a lot of irrigation in my area and the number 1 choice is electric where available and Deere where not.
olwhda
Posted 7/2/2012 21:53 (#2463135 - in reply to #2463049)
Liberty, MO
Does the crankcase vent tube go into the intake if front of the Turbo? If it does and this has happened to my 9190 DA 584 cubic inch BF6l913, there is a little rubber diaphram in a valve body at top end of that draft tube that can go bad and cause oil usage if pulled pretty hard, 14 to 16 lbs boost , this has been my experience.
As far a noise, the 374 cu in on the R 52 combine was loud, NO MUFFLER, the 9190 and 9150 are very quiet with a muffler.
plowboy
Posted 7/3/2012 04:05 (#2463523 - in reply to #2463135)
Brazilton KS
Bf6l913 is not nearly that big displacement. It's something close to 6 liters. I think your tractor has a different model engine.
Posted 7/3/2012 10:05 (#2463855 - in reply to #2463523)
BF6L913 is 6.128 litres.
You're right, it's not even close to 374 CID. My calculator says it's ONLY! 373.9535 CID ;-)
plowboy
Posted 7/3/2012 13:48 (#2464207 - in reply to #2463855)
Brazilton KS
"....my 9190 DA 584 cubic inch BF6l913,..."
I stated that I did not think that the BF6L913 was nearly that large of displacement, and I think it is not the engine used in a 9190."   I still believe this to be correct.
Jim in MS
Posted 7/2/2012 21:20 (#2463053 - in reply to #2462420)
very reliable and durable engine. seem to be better than average on fuel. I also have Perkins, Deere, and cummins. Parts are not cheap, but none are. Crackheads will not steal the radiator.
deeredriver
Posted 7/2/2012 21:26 (#2463074 - in reply to #2463053)
Alma NE
At least with a deutz you can send the new guy to go and check the antifreeze and stand back and watch how long he looks for the radiator ;)
mschultz
Posted 7/3/2012 01:34 (#2463500 - in reply to #2463074)
Oregon
Actually had a guy in our shop searching for the radiator on a Deutz powered compressor last week. Seriously... I would have let him look for the rest of the day but I need him to get back to work... -Mike
bmcpherson
Posted 7/2/2012 21:28 (#2463077 - in reply to #2462420)
Get the duetz or buy an izuzu. We have deere, duetz, izuzu, cummins, and Ford. The izuzu is by far the best on fuel in every application. But have had a lot little not picky problems with them. Nothing major just aggravating. The deere seems we have to overhaul one a year. The fords just run, and I mean run. They are loud and noisy and hard on fuel but seem to be bullet proof. The duetz is pretty much bullet proof as well. Ours had 6000 hrs on it when we bought it, now has 12000 and never been gone into. Front main has been leaking for 3 years about half a quart a day. I can live with that.
Bern
Posted 7/2/2012 22:38 (#2463244 - in reply to #2463077)
Mount Vernon, WA
I'm curious about the Ford. What model is it?
cocodrie
Posted 7/2/2012 23:53 (#2463396 - in reply to #2463244)
Mississippi Delta
I'm betting it is a 300 inline 6.
bmcpherson
Posted 7/2/2012 23:57 (#2463408 - in reply to #2463244)
I will have to check. These are older 4 cylinder diesel engines. I have never seen a number plate on them. Just says Ford on the engine covers.
Bern
Posted 7/3/2012 00:56 (#2463481 - in reply to #2463408)
Mount Vernon, WA
4 cylinder. That explains the noisy.
deereman05
Posted 7/2/2012 23:11 (#2463307 - in reply to #2462420)
Your moms house
Got 2 and had the first service call in 22 years that I know of it will run till after season
Deadduck
Posted 7/2/2012 23:35 (#2463360 - in reply to #2462420)
Northeast Louisiana
Lots of Deutz engines around here with over 10k ours and still running strong. Good engines.
