central mich | First you have to decide if you want single phase or three phase or both.
If you want to select a voltage and phase then you would need a switchable unit commonly called a "rental set". These units are on a trailer , with a fuel tank and are sound suppressed. They are about the most expensive as many will have at least a fuel tank to run 24 hrs at 100 % load. Then they increase to 48 hrs.
The smallest we sell new are 30kw, starting with an open set and progressing up to a "rental set" you can email us if you want pricing.
Right now we are testing a 600 kw with Volvo to determine if it will haul a load that we normally run with an 800kw with Cummins QSK23 G7. There are no new QSK23 G7 available right now so we can not build a set. CPL 1220, 1250 hp @1800 rpm.
Our largest rental set (not switchable) is 450 kw.
Deep Sea is the best control panel and all others are junk and expensive. Kohler, Generac are the worse and cheap built IMO. The Cummins Power Command is bad as well IMO.
Edited by jimgen 1/7/2021 19:53
