Posted 1/1/2021 19:01 (#8714641) Subject: Towable Air Compressor
SW MN
Picked this air compressor up and runs great until I close the large valve on the outlet and it starts to build pressure. Can only get 100 PSI until the engine dies. It appears as if the engine wants to die under load. The air operated throttle control appears to work but I’m not sure how to properly adjust linkage there or on carburetor. Or what else could be causing engine not to perform under load. TIA
