Posted 1/2/2021 07:53 (#8715593 - in reply to #8714518) Subject: RE: Upgrading lift assist cylinders JD 8640
EC GA
They will fit with some mods. The pin at the top is larger, so you will either have to bush the cylinder and use the small pins, or bore the rock shaft arm out to the larger size. They’re only a 1/4 in larger if I remember correctly.
