Posted 12/21/2020 17:45 (#8687533) Subject: Case 9270 won’t move forward
Will move in reverse every time forward it is a sometimes thing. Power shift have switched solenoids around cleaned all connections and grounds. Thought it could be the shifter switch dealership thought it checked out . pricey to see if that is the problem. Works and then doesn’t most times sooner or later it will go. Anyone had this problem and what did you do to fix it
