Posted 10/11/2018 11:14 (#7040347 - in reply to #7040313) Subject: RE: arrgh, wood finish problem
Crank up the shop heat for a day (reduce relative humidity, gets moisture out of finish more quickly) and respray. Can get a retarder to slow the lacquer drying and reduce the chances of this happening in the future.
Edit to add... clean the spot first, obviously. Only need a light coat over the affected area. Try less intrusive suggestions first.
