Northeast Nebraska | I've built a couple gates that wide with high tensile. Depending on how many wires you want and the post that you are using for the other fence. Mine had 5 wires, supported by fiberglass post cut off at ground level so it's as high as your other fence. Attach each wire to an insulator on a post. Then on the other side you you put a wire on the bottom side of the post that you hook the last fiberglass post into. On the top side you put a wire cable winch that slips over the top of the fiberglass post and use that to tighten.
this picture isn't very good and doesn't show the winch. I'll try and get some better once.
(IMG_3812 5 (full).JPG)
Attachments ---------------- IMG_3812 5 (full).JPG (130KB - 12 downloads)
