Posted 9/12/2017 14:01 (#6243427 - in reply to #6243238) Subject: RE: Thank you USDA!
SE ND
ehoff - 9/12/2017 00:10
Nodak where will you put your stops or will you?
I always use stops. As far as the location, it needs to be under structure, or in this case in corn, what you believe to be the swing low. If you're wrong...that's why you got the stop.
