SE SD | Get what YOU want, it's your money, your house and "hopefully" the
Plumber is not going to be living there with you :)
Check out a tub called " the big Ole" made by Warm Rain. I have installed several.
Just make sure to install it with a good sub base (concrete). VERY important.. :)
Edit to add, on demand water heater will resolve your hot water supply issue.
Edited by povertypoint 8/18/2017 08:46
