Posted 3/29/2017 22:43 (#5931815 - in reply to #5929071) Subject: RE: Outback STS integrated vs FM750 n ezsteer
central kansas reno county
Was you running on WAAS or something else. I have a couple outback systems and they are very simple and easy to use. I've got an ez steer system too and it tale alot to get it adjusted just right. So if your just running on wa as it will be just fine. I plant with it and spray too just can't run au to steer to spray down the rows.
