Central Illinois | I am adjusting the shims on the double disk openers and one unit is too wide regardless of the shims used. After further inspection, it appears as though one of the "studs" that the disks slide onto has been tweaked a little. Looking behind the with the disk openers installed, the angles are different. I don't believe you can replace those "studs" so my question is.....has anyone tried to bend it back? Thinking it will be difficult to get the right angle. If i try, should i take it all off and press or put nuts on it and try to bend with the unit still attached?
I suppose I could try to find a used bottom unit as a last resort.
Anyone have any advice for me?
Thanks | |
