| condition of the 45* degree unloading gears all the way up(think there are 3 sets of them) is most important. Better check if you can get those. If not your limited to salvage/used.
Depends what your or specificly how your grinding also,slow thru a shell corn screen,,,or fast thru an ear corn screen. You going to grind it fine like hog and chicken feed? Or coarse cracked?.
Not a bad grinder either one but will require fixin once in a while. Its easier to keep from bending the unlader if you have two people there while backing into tight quarters
Internet picture bidding is hard to know,,,guess you have to assume the worst and hope for the best. Can you go see it before hand?
Edited by don@nebr 3/27/2017 12:27
