Central-ish KY | Went to the dealer today and found out which solenoid is which. The one closer to the center of trans is forward and the one closer to the frame is reverse. I switch the connectors around. When placing the left hand reverser forward, the N light flashed and tractor doesn't move. When I move the LHR to reverse it goes forward. I would think this means the LHR is missing up and it's an electrical problem, not a mechanical one. I tried to check for voltage at the plug but got nothing. That could be because I'm by myself and couldn't check it instaneously. | |
