The Green Hills of Missouri | I will assume its a hammer mill. Check to see the condition of the hammers. The end of the lead end should be square. If one side rounded and the other side square you can rotate them for a sharp edge.
You best buy it cheap if you need to find a swinging unload. One thing about unload auger is it's very simple to add more length to it. I had to add ten feet to mine it reach a feed bin I have.
Good luck.
(20170227_150605.jpg)
Attachments ---------------- 20170227_150605.jpg (112KB - 38 downloads)
