Posted 3/21/2017 14:10 (#5913787 - in reply to #5913585) Subject: RE: 605M Vermeer Baler
Southwest Missouri
Like said from above keep some material feeding helps. Also see if it had the knife update put in it already that helped mine a lot and make sure the net deflector teeth,two of them one on each side are still there. Other then that make sure to run the break as tight as possible.
