Search Forums | Classifieds (7) | Skins | Language
Ag leader versa vechicle offsets changed
lino
Posted 3/9/2017 14:08 (#5888234)
Subject: Ag leader versa vechicle offsets changed
Wangaratta, Victoria, Australia
I have had my set up for 5 years now and last season l found my guidance was out by a metre.
I have my 1500 reciever 45 cm to the left of centre using a 16.5 metre mounted boom spray on a toyota ute. I had the guidance width set at 16 metres and decided to see what would happen if i set it at 16.5m to eliminate all overlap.
What i found was a metre overlap on one side and a metre gap on the other.
In the end i had to increase the left off set of the reciever to 90 cm to get the vechicle steering on the correct track.
Why bo you think this has happened any suggestions as if i put the offset back to 45 cm it is the guidance is out again.
