Those pics are of 2-7120's and a 7130. One 7120 with a 'bad' tranny (pic is in shed and the back side) is probably fixable as the cab is dirty but pretty much all there. Got it fired up this afternoon, thinking we got a bad flex plate, not a bad tranny. The other 7120 needs some TLC and another cab, I already have a donor engine out of a cotton picker. Was thinking about using the 7130 rear end on that tractor if I can find a mfwd front end. I'd get the bigger lift capacity on the 3pt and the heavier rear drive gears. May just make it a 7130 2wd. |
