Sw Ontario | The only way to do it right is to weigh the tractor with the implement hooked to it (if that gives any extra weight at all). Then look up your tire in the catalog of that brand and find the pressure rated for your weight capacity and speed you're running.
Make sure you have an accurate pressure gauge.
But why do you have such narrow tires on a tractor that you use for road work and pulling wagons ? | |
