dyersville, ia 52040 | i too have used the hydraulic height switch w/ my atu 200 very successfully for the past 2 years!
RobCam - 2/24/2017 13:43
Just hooking into the resume switch will not work, it is a momentary switch where an implement switch is an open/close. Ag Express makes a hydraulic height switch and if you don't want to install it on an implement you can make a scv coupler extension with the switch tee'd in. Then any implement you hook to that scv will have a height switch. |
