Strathcona, mn | From computing numbers in my had you are about on par with my old farm fans when dumping hot. I've comoared numbers to a friend running an in bin dryer set up and his numbers are significantly more to dry the same moisture crop. I'm in the same boat as my 2 old farm fans keep humming along and to replace them would be a major outlay of capital. My main dryer is a 3 stage continuous batch dryer. Kind of the predecessor to a full continuous flow. Im also interested to see others responses as to if there is efficency savings to be gained in a different dryer setup. | |
