Floyd County, Iowa | How did you move the snow before now? I'm thinking that using that blade on wet snow and soft ground is going to lead to a lot of gouging sod and moving gravel. Don't know where you are, but assuming it'll be a wet snow, and your ground/drive looks soft.
If you want it to stay down, the only way to help (besides adding weight) is to lengthen out the top link, making the bit dig under better. But it gets pretty aggressive that way. | |
