South Africa | Hi Guys
Need NAT to the rescue again.
Had a 3 point hitch installed on our new 600 Quadrac (yes here we still get 600 Tier 2 new) by the dealer. They shipped the tractor to us (1200 miles) and when we offloaded it here it had a Color Display Offline Fault and EHR Fault.
The Display is set to On in the instrument setup menu and powers up but does not detect any of the tractors controllers including the engine hours and PIN numbers.
The EHRs in the back will not assign either and can not be viewed, it says "No CAN Connection).
So me and the local CIH guy (who doesn't know Steigers well) ended up testing the voltages on the can and bot CAN Hi and CAN low tests 5.2 Volts instead of 2.5 or so...
Can't help thinking they screwed up somewhere with the wiring during the hitch installation.
Any ideas?
Can anyone help me with the hitch kit installation guide please? So I can at least double check the installation...
Need to get started on a tiling job at a customer and he's getting fed up waiting...
Thanks! | |
