Posted 1/23/2017 08:08 (#5787645 - in reply to #5787594) Subject: RE: Deweze super slicer
NW Kansas
They work great. We use ours to feed teff grass. It's very fine stem. Works the best if you feed the bale through it opisit the way it was baled. Then it just kind of unrolls however thick you have it set. Really doesn't cut the grass that much.
Also the teff bales do the same as you described when trying to unroll with the pickup.
