Posted 1/18/2017 16:34 (#5776863 - in reply to #5776607) Subject: RE: Hagie auto steer
NE South Dakota Clark, SD
John Deere calculates there lines different than everyone else. The only way to use you JD lines would be to figure out a way to use a JD display either with an ATU, which may be scary or find a JD tech that is up for a challenge. Good luck on the later.
