Posted 12/2/2016 09:28 (#5670726 - in reply to #5669855) Subject: RE: Var rate control into a Case IHC ADX3360 air tank
Carter Montana
I use an Integra. You have several choices if the cart has been converted to ISO use, a fairly cheap conversion. Other than that the 600 sounds like good advice.
