Fairfield, Mt | In the View box below the map, make sure you are looking at Base data.
to the left of the lower boxes you have options for Layers, Info, etc.
Select the blue circle i and this will bring up the information window.
Select the area in question using the mouse on the map. Several options available for how you want to select the area.
Info for area should be available when the selected area points turn black on the map. | |
