Light SwitchesNOTE: Combine is equipped with exit lighting. Exit lights will remain on for a maximum of 90 seconds after key switch is turned OFF if the road or field lights were in use within the previous five minutes. The operator can choose to light the left-hand or right-hand side of the combine using the turn signal lever. - (A) Dimmer, for all cab interior lights.
- (B) Hazard: Warning (flashing) lights, four road lights and tail lights (if engine is running) and turn signals.
- (C) Road: Warning (flashing) lights and four road lights, tail lights and turn signals.
- (D) Field: Grain tank and field lights (field position), and side finder lights ON with turn signal lever. Unloading auger light when auger is extended.
- (E) Work:
- Position 1: Stubble lights.
- Position 2: Stubble lights and rear residue lights.
| A-Dimmer for Cab Interior Lights B-Hazard Lights C-Road Lights D-Field Lights E-Work Lights
