Posted 10/28/2016 06:26 (#5604365 - in reply to #5604349) Subject: RE: Fan Switch shutting down boxcar magnum
Sounds like you need a new power strip stud and or cab solenoid. These are located under the fuses and relays on the cab floor. I have had good luck upgrading the solenoid with an 8900 series version.
