Posted 10/28/2016 05:29 (#5604317 - in reply to #5604164) Subject: RE: Bins, fans, heaters and corn
NW Central Ohio
...a propane low temp heater usually runs a lot cheaper. A great job of drying can be done if you have low temp heaters combined with a controller that only starts them when the humidity/temp is at the right level. That way they don't over dry the bottom of the bin.
