Posted 10/21/2016 20:00 (#5593513 - in reply to #5593504) Subject: RE: Motor uses oil. They think it could be bad piston rings.
NW Central Ohio
..there's really only one other place for oil to go unless you have a leak. It can be sucked in your intake valve stem, or run down your exhaust valve stem when you are at an idle. So...the guess that you have bad rings might be a 50/50 situation at least
