Federalsburg, MD | If you unplug the battery or turn off the power switch you will disable the span cable theft alerts if you have that hardware installed. You can check the box in notifications for low and bad battery for battery notifications.
I would highly recommend not messing with the power switch, they are on there so the units don't report to the Agsense website until they are installed. That switch isn't really made to be turned on and off a lot. | |
