NE Nebraska | The 20/20 was not connected to field view during planting, correct? Gen 1 20/20 with a field view module or a gen 2? When you have the 20/20 powered on and the iPad connected to it and in field view home page, does the iPad say connected in the lower right corner of the screen? Next go into settings, devices and make sure your 20/20 is connected. Next, go into data, 2016, and see how much memory a field has used, mine is about 1mb per acre planting and a total of 2 planting and harvest. If you have data for a field and still no map under that field and 2016 season, disconnect the 20/20, go into settings, data, 2016, then to the right of the field name press clear. One it has cleared you will be able to build that map again.
Hope this helps, if you have already tried this all, go to help and submit a ticket. The field file that will be attached should be named below and they are usually pretty quick about responding. | |
