Search Forums | Classifieds (23) | Skins | Language
yield monitor moisture
stecky1984
Posted 9/26/2016 06:49 (#5549495 - in reply to #5549349)
Subject: RE: yield monitor moisture
Bernard, IA
There should be an electric motor that continually takes samples, my guess is the fuse for it is blown or the motor is bad. It is probably plugged up with wet corn packed around the sample auger and needs to be cleaned out. Or your proximity switch for the sample auger is not working.
