Northern Illinois | Not a huge deal but issue comes up every year. Is there a way to correct the average yield (by adjusting actual pounds) after you go through the calibration? For example a person starts corn harvest in a 40 acre field. It takes a couple semis to get the yield monitor set correctly. My first load the yield monitor was 12% light on pounds. Second load was close so now hoping I have the adjustments done. But in a 40 that has 36 actual acres two loads can be close to 25% of the field. Again not a big deal because I know it was off but now going forward this field and variety are getting shorted. Would be nice to now be able to go in and put the actual pounds so that my running field average and hybrid average would be accurate.
JD 9670 with a 2600 display. | |
