NE South Dakota Clark, SD | Everyone should do some cleaning before using any yield data. Most yield data needs a lot of cleaning done before it is usable for anything other than a pretty colored picture. There is a lot of yield data that is complete junk even after cleanup. ARS Yield Editor can do a pretty good job of automatic cleanup by setting the parameters for the crop you are working with. That gets rid of 90 % of the bad points, then a little manual cleanup for what it missed and you have something that may be usable. |
