Iowa | I have a inline flow meter. I flow tested my 4650 and the IT manual says i need 26.5 gpm at 2000 rpm and 2000 psi. I installed the inlet at the line before the pressure control valve and the outlet in the right SCV with the lever held back. I got the oil warm and at 2000 rpm and 2000 psi it would drop down to 15 gpm. I just changed filters and the screen is clean. Did i not test it right or what else can i look for? thanks! | |
