Posted 8/24/2016 08:45 (#5487044 - in reply to #5486596) Subject: RE: GS3 yield map wet yield only??
Eastern Nebraska
That is the only option. You're doing nothing wrong. If you look at documentation, it shows dry there. Just ignore the "wet" part on the ACTUAL map. It's not mapping it as wet. Then on the command center, you can change the checkbox like you said you did already from dry to wet. Just leave it check marked on dry.
